주요 콘텐츠로 건너뛰기
Garmin Vivoactive HR Display Replacement
필요한 것
  1. Garmin Vivoactive HR Display Replacement, Display: 1 단계, 이미지 1/1
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: 2 단계, 이미지 1/1
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
  3. Garmin Vivoactive HR Display Replacement: 3 단계, 이미지 1/1
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: 4 단계, 이미지 1/2 Garmin Vivoactive HR Display Replacement: 4 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Chris Corry
회원 가입일: 07/05/18
256 평판
안내서 1개 작성함
IUPUI, Team S2-G5, Harley Summer 2018 IUPUI, Team S2-G5, Harley Summer 2018 회원
IUPUI-HARLEY-SU18S2G5
3 회원들
안내서 3개 작성하였습니다
댓글 19개
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - 답글
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - 답글
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - 답글
What type of glue i use to connect the display an the body?
culibrkboj - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 89
전체 시간: 25,953
