소개
The replacing antenna guide shows step by step how to install a new antenna.
필요한 것
Flip the device to the backside, and locate the metal tab at the center of the back cover.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
다른 한 분이 해당 안내서를 완성하였습니다.
