주요 콘텐츠로 건너뛰기
Garmin fenix 6X Sapphire Back Cover Replacement
필요한 것
  1. Garmin fenix 6X Sapphire Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the watch so the face is down.
    • Remove the five 6 mm T5 Torx screws on the back of the watch.
  2. Garmin fenix 6X Sapphire Back Cover Replacement: 2 단계, 이미지 1/3 Garmin fenix 6X Sapphire Back Cover Replacement: 2 단계, 이미지 2/3 Garmin fenix 6X Sapphire Back Cover Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry the back cover of the watch off by placing it under the seam of the back case.
    • The back cover is glued on and may be difficult to remove. It might help to heat the back cover before prying in order to soften the glue. If doing so, be careful to not burn yourself.
    • This step requires a good bit of force to pry or apply heat back cover off because the back cover is glued. Be careful not to the break cover from too much force.
결론
matthew long
회원 가입일: 02/22/22
537 평판
안내서 5개 작성하였습니다
Clemson, Team 1-5, Hunter Spring 2022 Clemson, Team 1-5, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 22
30일 전: 79
전체 시간: 2,226
