주요 콘텐츠로 건너뛰기
Garmin fenix 6X Sapphire Display Replacement
필요한 것
  1. Garmin fenix 6X Sapphire Display Replacement, Display: 1 단계, 이미지 1/1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Display Replacement: 2 단계, 이미지 1/2 Garmin fenix 6X Sapphire Display Replacement: 2 단계, 이미지 2/2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
결론
다른 5명이 해당 안내서를 완성하였습니다.
matthew long
회원 가입일: 02/22/22
537 평판
안내서 5개 작성하였습니다
Clemson, Team 1-5, Hunter Spring 2022 Clemson, Team 1-5, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G5
4 회원들
안내서 8개 작성하였습니다
댓글 2개
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - 답글
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 51
30일 전: 216
전체 시간: 7,461
