주요 콘텐츠로 건너뛰기
Garmin nüvi 3590 LMT Battery Replacement
필요한 것
  1. Garmin nüvi 3590 LMT Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device off by pressing and holding the power button on the top left of the device.
  2. Garmin nüvi 3590 LMT Battery Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
  3. Garmin nüvi 3590 LMT Battery Replacement: 3 단계, 이미지 1/1
    • Once all of the tabs are popped out, take the back cover off.
    • The back cover is a separate piece from the device.
  4. Garmin nüvi 3590 LMT Battery Replacement: 4 단계, 이미지 1/2 Garmin nüvi 3590 LMT Battery Replacement: 4 단계, 이미지 2/2
    • Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
  5. Garmin nüvi 3590 LMT Battery Replacement: 5 단계, 이미지 1/3 Garmin nüvi 3590 LMT Battery Replacement: 5 단계, 이미지 2/3 Garmin nüvi 3590 LMT Battery Replacement: 5 단계, 이미지 3/3
    • Use the plastic spudger to lift the battery up and away from the device.
    • Do not puncture or bend the battery. Serious health complications could occur.
결론
다른 7명이 해당 안내서를 완성하였습니다.
David
회원 가입일: 03/11/15
424 평판
안내서 3개 작성하였습니다
Colorado Springs, Team 4-1, Panko Spring 2015 Colorado Springs, Team 4-1, Panko Spring 2015 회원
UCCS-PANKO-S15S4G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 32
전체 시간: 3,516
