메인 컨텐츠로 가기
소개
This guide will teach users how to replace a damaged or non-functional speaker for the Garmin nüvi 3590.
  1. Turn the device off by pressing and holding the power button on the top left of the device.
    • Turn the device off by pressing and holding the power button on the top left of the device.
  2. Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
    • Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
  3. Once all of the tabs are popped out, take the back cover off.
    • Once all of the tabs are popped out, take the back cover off.
    • The back cover is a separate piece from the device.
  4. Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected. Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
    • Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
  5. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  6. Use the plastic spudger to lift the battery up and away from the device. Do not puncture or bend the battery. Serious health complications could occur. Do not puncture or bend the battery. Serious health complications could occur.
    • Use the plastic spudger to lift the battery up and away from the device.
    • Do not puncture or bend the battery. Serious health complications could occur.
  7. Using the T5 bit, unscrew the four 5.7mm screws in the four corners of the device. Using the T5 bit, unscrew the four 5.7mm screws in the four corners of the device.
    • Using the T5 bit, unscrew the four 5.7mm screws in the four corners of the device.
  8. Leverage the plastic opening tool to pop the tabs between the black screen and the metal frame. Carefully work around the perimeter of the frame. Do not forcibly separate the two pieces after the tabs have been popped as there are connections between the two pieces that could be torn. Do not forcibly separate the two pieces after the tabs have been popped as there are connections between the two pieces that could be torn.
    • Leverage the plastic opening tool to pop the tabs between the black screen and the metal frame. Carefully work around the perimeter of the frame.
    • Do not forcibly separate the two pieces after the tabs have been popped as there are connections between the two pieces that could be torn.
  9. Using your fingers, remove the red and black wire from the back of the screen. This is the connection to the light sensor, not the speaker.
    • Using your fingers, remove the red and black wire from the back of the screen. This is the connection to the light sensor, not the speaker.
  10. Pull up on the smaller orange tab with your finger from the circuit board. This connection will unplug with ease. Pull up on the smaller orange tab with your finger from the circuit board. This connection will unplug with ease.
    • Pull up on the smaller orange tab with your finger from the circuit board. This connection will unplug with ease.
  11. For the larger orange connection, there is a white tab holding the connection to the circuit board. Lift this tab gently with the wide tipped tweezers or the plastic spudger and remove the orange connection from the circuit board. After the white tab is lifted, slide the ribbon connector out from the circuit board.
    • For the larger orange connection, there is a white tab holding the connection to the circuit board.
    • Lift this tab gently with the wide tipped tweezers or the plastic spudger and remove the orange connection from the circuit board.
    • After the white tab is lifted, slide the ribbon connector out from the circuit board.
  12. Locate the red and black wire that connects the speaker to the circuit board. Use your fingers (or tweezers) to gently lift the plug off the circuit board. Locate the red and black wire that connects the speaker to the circuit board. Use your fingers (or tweezers) to gently lift the plug off the circuit board. Locate the red and black wire that connects the speaker to the circuit board. Use your fingers (or tweezers) to gently lift the plug off the circuit board.
    • Locate the red and black wire that connects the speaker to the circuit board. Use your fingers (or tweezers) to gently lift the plug off the circuit board.
  13. With the plastic spudger, lift the speaker up and out of the frame. With the plastic spudger, lift the speaker up and out of the frame. With the plastic spudger, lift the speaker up and out of the frame.
    • With the plastic spudger, lift the speaker up and out of the frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David
회원 가입일: 2015년 03월 11일
412 Reputation
안내서 3개 작성하였습니다
Colorado Springs, Team 4-1, Panko Spring 2015 Colorado Springs, Team 4-1, Panko Spring 2015 회원
UCCS-PANKO-S15S4G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 344
