주요 콘텐츠로 건너뛰기
Garmin nuvi 2460 LMT Screen Replacement
필요한 것
  1. Garmin nuvi 2460 LMT Screen Replacement, Back Cover: 1 단계, 이미지 1/2 Garmin nuvi 2460 LMT Screen Replacement, Back Cover: 1 단계, 이미지 2/2
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Screen Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Screen Replacement: 3 단계, 이미지 1/1
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Screen Replacement: 4 단계, 이미지 1/1
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Pop out the panel along the edges and remove it from the border.
결론
Ricardo Audain
회원 가입일: 09/07/16
671 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-4, Remmell Fall 2016 USF Tampa, Team 6-4, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 431
