주요 콘텐츠로 건너뛰기
Garmin nuviCam LMTHD Battery Replacement
필요한 것
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: 1 단계, 이미지 2개 중 1개 Garmin nuviCam LMTHD Battery Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Battery Replacement: 2 단계, 이미지 2개 중 1개 Garmin nuviCam LMTHD Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Battery Replacement: 4 단계, 이미지 2개 중 1개 Garmin nuviCam LMTHD Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sarah Myers
회원 가입일: 01/19/17
427 평판
안내서 3개를 작성함
4가이드 댓글
Where did you buy the battery? What is the voltage/current?
John Justin - 답글
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
Gary - 답글
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
guy.adamson - 답글
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
Zach - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 44
전체 시간: 5,484
