주요 콘텐츠로 건너뛰기
Gas Grill Ceramic Briquettes Replacement
필요한 것
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: 1 단계, 이미지 1/3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: 1 단계, 이미지 2/3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: 1 단계, 이미지 3/3
    • Carefully lift grill plate located above briquettes
    • Make sure the gas grill is off and the propane is turned off before removing the grill plate
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: 2 단계, 이미지 1/3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: 2 단계, 이미지 2/3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: 2 단계, 이미지 3/3
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: 3 단계, 이미지 1/3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: 3 단계, 이미지 2/3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: 3 단계, 이미지 3/3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
    • A small container is recommended to keep the screws together
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: 4 단계, 이미지 1/3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: 4 단계, 이미지 2/3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: 4 단계, 이미지 3/3
    • Using your hands, gently unscrew washers from the back of the casing.
    • A small container is recommended to keep the washers together
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: 5 단계, 이미지 1/3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: 5 단계, 이미지 2/3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: 5 단계, 이미지 3/3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: 6 단계, 이미지 1/1
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: 7 단계, 이미지 1/1
    • Take 16 new ceramic briquettes out and carefully align them inside the casing.
    • Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
emma
회원 가입일: 01/27/16
173 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 회원
USFSM-STEWART-S16S1G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 45
전체 시간: 3,506
