소개
The seals of the inlet valve are under a lot of strain and need to be replaced from time to time. The replacement is easy. This will show you how to do this.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
필요한 것
Here you see the removed socket. Note the double O-rings.
Open the valve to do this, the slot at the upper end must be twisted a little, then the inside comes out. Check the spring, the valve stem and the two seals. When assembling, pay attention to the correct position of the valve stamp: it must point to the water inlet side, otherwise the valve will not open! (Third picture shows wrong direction)
Replace the seals on the nozzle and lightly grease them with food grade silicone grease.
Work through the steps in reverse order to re-assemble your device.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
