주요 콘텐츠로 건너뛰기
Gateway 3545GZ Fan Replacement
필요한 것
  1. Gateway 3545GZ Fan Replacement, Fan: 1 단계, 이미지 2개 중 1개 Gateway 3545GZ Fan Replacement, Fan: 1 단계, 이미지 2개 중 2개
    • Unscrew 14mm screws with Phillips screwdriver.
    • Unscrew 3mm screws with the same Phillips screwdriver.
    • Screws that are circled in red are 3mm; the screw circled in blue is 14mm
    • Remove the protective cover.
  2. Gateway 3545GZ Fan Replacement: 2 단계, 이미지 3개 중 1개 Gateway 3545GZ Fan Replacement: 2 단계, 이미지 3개 중 2개 Gateway 3545GZ Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the four screws holding it in place with the same PH1 Phillips-Head screwdriver. They are numbered on the fan, 1,2,3,4.
    • The four screws are 12mm long, they also have a spring surrounding them.
    • Then carefully pull the cord connecting the fan to the notebook.
    • Insert your replacement fan, plug in its cord, screw it into place, and reattach the protective cover.
결론
작성자
5다른 기여자 명과 함께
Nathan Parr
회원 가입일: 09/12/16
25 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 6
전체 시간: 257
