주요 콘텐츠로 건너뛰기
Gateway 3545GZ Hard Drive Replacement
필요한 것
  1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
    • Screw Length: 3mm
  2. Gateway 3545GZ Hard Drive Replacement: 2 단계, 이미지 1/1
    • Lift up the plastic plate from the outer edge.
  3. Gateway 3545GZ Hard Drive Replacement: 3 단계, 이미지 1/1
    • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
결론
Bryan Rickle
회원 가입일: 09/12/16
1 평판
안내서 1개 작성함
Western Carolina University, Team 1-5, Virtue Fall 2016 Western Carolina University, Team 1-5, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 8
전체 시간: 274
