주요 콘텐츠로 건너뛰기
Gateway 600YG2 CPU Replacement
필요한 것
  1. Gateway 600YG2 CPU Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 CPU Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery cover using the tab on the right side.
    • Use your index finger to help lift and remove the battery.
  3. Gateway 600YG2 CPU Replacement, Power Button Panel: 3 단계, 이미지 1개 중 1개
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 CPU Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove the 5 screws holding the keyboard in place.
  5. Gateway 600YG2 CPU Replacement: 5 단계, 이미지 2개 중 1개 Gateway 600YG2 CPU Replacement: 5 단계, 이미지 2개 중 2개
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Gateway 600YG2 CPU Replacement, System Fan: 6 단계, 이미지 2개 중 1개 Gateway 600YG2 CPU Replacement, System Fan: 6 단계, 이미지 2개 중 2개
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
  7. Gateway 600YG2 CPU Replacement, CPU: 7 단계, 이미지 1개 중 1개
    • Turn screw 1/4 turn to the right.
    • When reinstalling ensure proper orientation the yellow arrow on CPU should be in upper left corner
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elizabeth Mazer
회원 가입일: 10/14/10
78 평판
안내서 10개를 작성함
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 회원
CPSU-MANESS-F10S20G10
3 회원들
안내서 22개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,985
