이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Remove the battery cover using the tab on the right side.
Take the battery out with your index finger.
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Follow the black ribbon cable to the connector and gently pull straight up.
