주요 콘텐츠로 건너뛰기
Gateway 600YG2 LCD Replacement
필요한 것
  1. Gateway 600YG2 LCD Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 LCD Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: 3 단계, 이미지 1/1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 LCD Replacement, LCD: 4 단계, 이미지 1/1
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  5. Gateway 600YG2 LCD Replacement: 5 단계, 이미지 1/1
    • Gently unplug the LCD from the system board.
  6. Gateway 600YG2 LCD Replacement: 6 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: 7 단계, 이미지 1/1
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
결론
Elizabeth Mazer
회원 가입일: 10/14/10
78 평판
안내서 10개 작성하였습니다
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 회원
CPSU-MANESS-F10S20G10
3 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 1,877
