주요 콘텐츠로 건너뛰기
Gateway GWTC116-2BL Motherboard Replacement
필요한 것
  1. Gateway GWTC116-2BL Motherboard Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Motherboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Motherboard Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
  7. Gateway GWTC116-2BL Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
  8. Gateway GWTC116-2BL Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
  9. Gateway GWTC116-2BL Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Gateway GWTC116-2BL Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
  10. Gateway GWTC116-2BL Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
  11. Gateway GWTC116-2BL Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Peel off the black piece of tape covering the display cable.
  12. Gateway GWTC116-2BL Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Gateway GWTC116-2BL Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
  13. Gateway GWTC116-2BL Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the motherboard from the device.
결론
작성자
2다른 기여자 명과 함께
Christian Chapman
회원 가입일: 03/25/24
192 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-2, Botvin Spring 2024 UMass Dartmouth, Team 6-2, Botvin Spring 2024 회원
UMASSD-BOTVIN-S24S6G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 42
전체 시간: 776
