주요 콘텐츠로 건너뛰기
Gateway ID49C07U Screen Replacement
필요한 것
  1. Gateway ID49C07U Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: 2 단계, 이미지 2개 중 1개 Gateway ID49C07U Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: 4 단계, 이미지 1개 중 1개
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: 6 단계, 이미지 2개 중 1개 Gateway ID49C07U Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: 7 단계, 이미지 2개 중 1개 Gateway ID49C07U Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: 9 단계, 이미지 3개 중 1개 Gateway ID49C07U Screen Replacement: 9 단계, 이미지 3개 중 2개 Gateway ID49C07U Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: 10 단계, 이미지 3개 중 1개 Gateway ID49C07U Screen Replacement: 10 단계, 이미지 3개 중 2개 Gateway ID49C07U Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: 11 단계, 이미지 2개 중 1개 Gateway ID49C07U Screen Replacement: 11 단계, 이미지 2개 중 2개
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: 13 단계, 이미지 2개 중 1개 Gateway ID49C07U Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Hold the tape back with one hand and pull the connector out
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan Howlett
회원 가입일: 03/06/17
273 평판
안내서 2개를 작성함
UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S6G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 6
전체 시간: 442
