이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Carefully disconnect two ribbon cables to complete the separation of the upper cover.
Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
Be careful not to damage the computer screen in the process
Separate the monitor from the border cover once all snap connections have been pried apart.
Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
