주요 콘텐츠로 건너뛰기
Gateway KAV60 LT2016U WiFi Card Replacement
필요한 것
  1. Gateway KAV60 LT2016U WiFi Card Replacement, Battery: 1 단계, 이미지 3개 중 1개 Gateway KAV60 LT2016U WiFi Card Replacement, Battery: 1 단계, 이미지 3개 중 2개 Gateway KAV60 LT2016U WiFi Card Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U WiFi Card Replacement, Upper Cover: 2 단계, 이미지 1개 중 1개
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U WiFi Card Replacement: 3 단계, 이미지 2개 중 1개 Gateway KAV60 LT2016U WiFi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U WiFi Card Replacement: 4 단계, 이미지 3개 중 1개 Gateway KAV60 LT2016U WiFi Card Replacement: 4 단계, 이미지 3개 중 2개 Gateway KAV60 LT2016U WiFi Card Replacement: 4 단계, 이미지 3개 중 3개
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U WiFi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U WiFi Card Replacement: 6 단계, 이미지 2개 중 1개 Gateway KAV60 LT2016U WiFi Card Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
  7. Gateway KAV60 LT2016U WiFi Card Replacement, WiFi Card: 7 단계, 이미지 2개 중 1개 Gateway KAV60 LT2016U WiFi Card Replacement, WiFi Card: 7 단계, 이미지 2개 중 2개
    • The WiFi card is shown here.
    • Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
  8. Gateway KAV60 LT2016U WiFi Card Replacement: 8 단계, 이미지 2개 중 1개 Gateway KAV60 LT2016U WiFi Card Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Lydia Benjock
회원 가입일: 10/18/13
1,216 평판
안내서 10개를 작성함
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 회원
CLEM-BENSON-F13S14G3
3 회원들
안내서 22개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 1,531
