주요 콘텐츠로 건너뛰기
Gateway LT41P10u Monitor Replacement
필요한 것
  1. Gateway LT41P10u Monitor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Monitor Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Monitor Replacement: 3 단계, 이미지 1개 중 1개
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  4. Gateway LT41P10u Monitor Replacement, Monitor: 4 단계, 이미지 2개 중 1개 Gateway LT41P10u Monitor Replacement, Monitor: 4 단계, 이미지 2개 중 2개
    • Carefully use a spudger to separate the monitor from top panel.
    • Gently remove lower hooks from the hinges. (see second image)
  5. Gateway LT41P10u Monitor Replacement: 5 단계, 이미지 2개 중 1개 Gateway LT41P10u Monitor Replacement: 5 단계, 이미지 2개 중 2개
    • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
    • The second image is how it should look once completely disconnected.
결론
To reinstall your device, follow these instructions in reverse order.
작성자
2다른 기여자 명과 함께
Michael Smith
회원 가입일: 10/19/17
401 평판
안내서 4개를 작성함
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 UMass Dartmouth, Team S66-G8, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S66G8
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 340
