주요 콘텐츠로 건너뛰기
Gateway M-2626u Hard Drive Replacement
필요한 것
  1. Gateway M-2626u Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Gateway M-2626u Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Gateway M-2626u Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Gateway M-2626u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Gateway M-2626u Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Gateway M-2626u Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Using your hands, carefully pull out the hard drive from its compartment.
결론
작성자
3다른 기여자 명과 함께
Femi
회원 가입일: 04/06/18
219 평판
안내서 2개를 작성함
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G7
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 260
