주요 콘텐츠로 건너뛰기
Gateway M-2626u RAM Replacement
필요한 것
  1. Gateway M-2626u RAM  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: 2 단계, 이미지 3개 중 1개 Gateway M-2626u RAM  Replacement: 2 단계, 이미지 3개 중 2개 Gateway M-2626u RAM  Replacement: 2 단계, 이미지 3개 중 3개
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 Gateway M-2626u RAM  Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: 4 단계, 이미지 2개 중 1개 Gateway M-2626u RAM  Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: 5 단계, 이미지 1개 중 1개
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: 6 단계, 이미지 2개 중 1개 Gateway M-2626u RAM  Replacement: 6 단계, 이미지 2개 중 2개
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
결론
작성자
1다른 기여자 명과 함께
Tanya Jain
회원 가입일: 03/19/18
320 평판
안내서 3개를 작성함
UMass Dartmouth, Team S3-G2, Peak Spring 2018 UMass Dartmouth, Team S3-G2, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G2
2 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 257
