주요 콘텐츠로 건너뛰기
Gateway MA6 Laptop Hard Drive Replacement
필요한 것
  1. Gateway MA6 Laptop Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Hard Drive Replacement: 2 단계, 이미지 1/3 Gateway MA6 Laptop Hard Drive Replacement: 2 단계, 이미지 2/3 Gateway MA6 Laptop Hard Drive Replacement: 2 단계, 이미지 3/3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
  4. Gateway MA6 Laptop Hard Drive Replacement: 4 단계, 이미지 1/2 Gateway MA6 Laptop Hard Drive Replacement: 4 단계, 이미지 2/2
    • Press thumb down firmly on the hard drive and pull outwards to the side.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chris Naughton
회원 가입일: 04/07/14
705 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 회원
CPSU-FORTE-S14S6G2
5 회원들
안내서 20개 작성하였습니다
댓글 한 개
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,850
