주요 콘텐츠로 건너뛰기
Gateway MA6 Laptop Wireless Card Replacement
필요한 것
  1. Gateway MA6 Laptop Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Wireless Card Replacement: 2 단계, 이미지 3개 중 1개 Gateway MA6 Laptop Wireless Card Replacement: 2 단계, 이미지 3개 중 2개 Gateway MA6 Laptop Wireless Card Replacement: 2 단계, 이미지 3개 중 3개
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: 3 단계, 이미지 2개 중 1개 Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: 3 단계, 이미지 2개 중 2개
    • Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
    • The screw will remain in the backplate.
    • Lift upwards on the back plate to remove it.
  4. Gateway MA6 Laptop Wireless Card Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently pry upwards on the two connecting cables to remove them.
  5. Gateway MA6 Laptop Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 2 mm Phillips #0 screw.
    • The card will lift itself up 30° after the screw has been removed.
  6. Gateway MA6 Laptop Wireless Card Replacement: 6 단계, 이미지 2개 중 1개 Gateway MA6 Laptop Wireless Card Replacement: 6 단계, 이미지 2개 중 2개
    • Hold the WiFi card on both sides and pull outwards to remove it.
결론
작성자
4다른 기여자 명과 함께
Chris Naughton
회원 가입일: 04/07/14
705 평판
안내서 5개를 작성함
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 회원
CPSU-FORTE-S14S6G2
5 회원들
안내서 20개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 774
