주요 콘텐츠로 건너뛰기
Gateway MA7 CD/DVD Drive Replacement
필요한 것
  1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1/1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while puling out the battery.
  2. Gateway MA7 CD/DVD Drive Replacement: 2 단계, 이미지 1/2 Gateway MA7 CD/DVD Drive Replacement: 2 단계, 이미지 2/2
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
  3. Gateway MA7 CD/DVD Drive Replacement: 3 단계, 이미지 1/3 Gateway MA7 CD/DVD Drive Replacement: 3 단계, 이미지 2/3 Gateway MA7 CD/DVD Drive Replacement: 3 단계, 이미지 3/3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 CD/DVD Drive Replacement: 4 단계, 이미지 1/2 Gateway MA7 CD/DVD Drive Replacement: 4 단계, 이미지 2/2
    • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
  5. Gateway MA7 CD/DVD Drive Replacement: 5 단계, 이미지 1/1
    • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
    • While pressing down, push the metal latch out away from the laptop.
  6. Gateway MA7 CD/DVD Drive Replacement: 6 단계, 이미지 1/3 Gateway MA7 CD/DVD Drive Replacement: 6 단계, 이미지 2/3 Gateway MA7 CD/DVD Drive Replacement: 6 단계, 이미지 3/3
    • Once the drive has been pried out, you can pull the CD drive out.
결론
Tim Rose
회원 가입일: 03/05/18
392 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 484
