주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Gateway MD2614u Fan Replacement
필요한 것
  1. Gateway MD2614u Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Fan Replacement: 2 단계, 이미지 1/1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Fan Replacement: 3 단계, 이미지 1/1
    • Lift off the cover.
  4. Gateway MD2614u Fan Replacement, Fan: 4 단계, 이미지 1/1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Fan Replacement: 5 단계, 이미지 1/1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Fan Replacement: 6 단계, 이미지 1/1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Fan Replacement: 7 단계, 이미지 1/1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Toni Pipes
회원 가입일: 10/05/10
333 평판
안내서 7개 작성하였습니다
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 회원
CPSU-REGAN-F10S21G31
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,900
