주요 콘텐츠로 건너뛰기
Gateway MD2614u Processor Replacement
필요한 것
  1. Gateway MD2614u Processor Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: 3 단계, 이미지 1개 중 1개
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: 4 단계, 이미지 1개 중 1개
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: 6 단계, 이미지 1개 중 1개
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: 9 단계, 이미지 1개 중 1개
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Toni Pipes
회원 가입일: 10/05/10
333 평판
안내서 7개를 작성함
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 회원
CPSU-REGAN-F10S21G31
4 회원들
안내서 14개를 작성함
1가이드 댓글
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 7,366
