소개
The Central Processing Unit (CPU) is an integral part of your computer's speed and ability to process information. A damaged CPU may cause your computer to become slow and unstable, resulting in frequent crashes or even inability to boot. Replacing the CPU will enhance the speed and overall performance of your device. Because of its importance, it can get very expensive to replace. This simple and easy-to-follow guide that requires no special skills will walk you through the steps of replacing the CPU for a Gateway MD2614u.
필요한 것
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
The CPU is located under the heat sink you just removed.
Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - 답글
