주요 콘텐츠로 건너뛰기
Gateway MD2614u Wireless Card Replacement
필요한 것
  1. Gateway MD2614u Wireless Card Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Wireless Card Replacement: 3 단계, 이미지 1개 중 1개
    • Lift off the cover.
  4. Gateway MD2614u Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • The wireless card is located to the right of the hard drive and below the RAM.
  5. Gateway MD2614u Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • There are black and grey wires with gold heads attached to the top of the wireless card.
    • To remove these wires, turn the gold heads counterclockwise and pull up.
    • You will hear a snap when the heads come off.
    • It does not matter which wire you remove first, but do so one at a time.
  6. Gateway MD2614u Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two screws next to the wires with a Phillips #00 screwdriver.
  7. Gateway MD2614u Wireless Card Replacement: 7 단계, 이미지 1개 중 1개
    • The card will pop up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card out to the left horizontally.
결론
작성자
10다른 기여자 명과 함께
Toni Pipes
회원 가입일: 10/05/10
333 평판
안내서 7개를 작성함
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 회원
CPSU-REGAN-F10S21G31
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 4,452
