주요 콘텐츠로 건너뛰기
Gateway MS2285 Hard Drive Replacement
필요한 것
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: 2 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: 2 단계, 이미지 2개 중 2개
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: 3 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Release The Battery: 3 단계, 이미지 2개 중 2개
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: 4 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Remove The Battery: 4 단계, 이미지 2개 중 2개
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: 5 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: 5 단계, 이미지 2개 중 2개
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: 6 단계, 이미지 3개 중 1개 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: 6 단계, 이미지 3개 중 2개 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: 6 단계, 이미지 3개 중 3개
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: 7 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: 7 단계, 이미지 2개 중 2개
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: 8 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: 8 단계, 이미지 2개 중 2개
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: 9 단계, 이미지 3개 중 1개 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: 9 단계, 이미지 3개 중 2개 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: 9 단계, 이미지 3개 중 3개
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: 10 단계, 이미지 2개 중 1개 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: 10 단계, 이미지 2개 중 2개
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chris mello
회원 가입일: 10/22/14
331 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-7, Shastany Fall 2014 UMass Dartmouth, Team 1-7, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G7
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 8
전체 시간: 3,855
