주요 콘텐츠로 건너뛰기
Gateway MS2370 RAM Replacement
필요한 것
  1. Gateway MS2370 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
    • Unscrew the three 10mm inch Phillips 01 screws on the back of your laptop.
    • Unplug everything from the USB and SD ports.
  5. Gateway MS2370 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the cover panel.
    • This exposes more screws that must be removed.
  6. Gateway MS2370 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the two exposed cables from the motherboard.
  7. Gateway MS2370 RAM Replacement: 7 단계, 이미지 2개 중 1개 Gateway MS2370 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
    • This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
  8. Gateway MS2370 RAM Replacement: 8 단계, 이미지 2개 중 1개 Gateway MS2370 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the laptop case apart.
    • The disc drive in this photo was removed. You can remove it just by puling it out when the previous step is completed.
  9. Gateway MS2370 RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
    • This cable has a special connector the requires you to lift open a grey flap to unplug properly.
    • The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
  10. Gateway MS2370 RAM Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the top half of the case.
  11. Gateway MS2370 RAM Replacement: 11 단계, 이미지 1개 중 1개
    • Unscrew all 5 10mm inch Phillips 01 screws.
    • One more off screen
  12. Gateway MS2370 RAM Replacement: 12 단계, 이미지 3개 중 1개 Gateway MS2370 RAM Replacement: 12 단계, 이미지 3개 중 2개 Gateway MS2370 RAM Replacement: 12 단계, 이미지 3개 중 3개
    • Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
  13. Gateway MS2370 RAM Replacement: 13 단계, 이미지 1개 중 1개
    • Flip the motherboard over.
  14. Gateway MS2370 RAM Replacement: 14 단계, 이미지 3개 중 1개 Gateway MS2370 RAM Replacement: 14 단계, 이미지 3개 중 2개 Gateway MS2370 RAM Replacement: 14 단계, 이미지 3개 중 3개
    • Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
    • The last step of this replacement guide is not required to complete the fan replacement guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mathieu Bolduc-Clayton
회원 가입일: 10/17/17
518 평판
안내서 4개를 작성함
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 1,798
