주요 콘텐츠로 건너뛰기
Gateway MS2370 Screen Replacement
필요한 것
  1. Gateway MS2370 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: 5 단계, 이미지 2개 중 1개 Gateway MS2370 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: 9 단계, 이미지 3개 중 1개 Gateway MS2370 Screen Replacement: 9 단계, 이미지 3개 중 2개 Gateway MS2370 Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: 10 단계, 이미지 2개 중 1개 Gateway MS2370 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Slowly remove the screen from the laptop.
결론
작성자
3다른 기여자 명과 함께
Mathieu Bolduc-Clayton
회원 가입일: 10/17/17
518 평판
안내서 4개를 작성함
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 801
