주요 콘텐츠로 건너뛰기
  1. Ensure device is powered off and unplugged from a power source. Place the device upside down.
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  4. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  5. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
결론
Jared Lotfi
회원 가입일: 2018년 01월 31일
283 평판
안내서 2개 작성하였습니다
University of Alabama, Team S2-G8, Bedsole Spring 2018 University of Alabama, Team S2-G8, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S2G8
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 81
