주요 콘텐츠로 건너뛰기
Gateway NE51006u RAM Replacement
필요한 것
  1. Gateway NE51006u RAM Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Gateway NE51006u RAM Replacement: 2 단계, 이미지 1/1
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Gateway NE51006u RAM Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  4. Gateway NE51006u RAM Replacement: 4 단계, 이미지 1/3 Gateway NE51006u RAM Replacement: 4 단계, 이미지 2/3 Gateway NE51006u RAM Replacement: 4 단계, 이미지 3/3
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  5. Gateway NE51006u RAM Replacement: 5 단계, 이미지 1/3 Gateway NE51006u RAM Replacement: 5 단계, 이미지 2/3 Gateway NE51006u RAM Replacement: 5 단계, 이미지 3/3
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
  6. Gateway NE51006u RAM Replacement, RAM: 6 단계, 이미지 1/3 Gateway NE51006u RAM Replacement, RAM: 6 단계, 이미지 2/3 Gateway NE51006u RAM Replacement, RAM: 6 단계, 이미지 3/3
    • Use your fingers to pull the two metal hinges on either side of the RAM card.
    • From here the card should lift upwards and pull off of the device easily.
결론
Omer Tunagur
회원 가입일: 01/29/18
423 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G8, Bedsole Spring 2018 University of Alabama, Team S2-G8, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S2G8
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 303
