소개
If you can't connect to a wireless internet signal, a faulty wireless card is most likely the problem and you’ll have to replace it with a functioning one. This guide will provide you with the steps necessary to replace your old wireless card with a new one, so you can get back to surfing the web!
필요한 것
Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
Remove 5 6.0 mm Phillip #00 screws from under cover.
이 단계에 사용된 도구:Tweezers$4.99
Grab the antenna cable with tweezers and lift up to pull it off.
거의 끝나갑니다!
결론
