주요 콘텐츠로 건너뛰기
Gateway NE52214U Fan Replacement
필요한 것
  1. Gateway NE52214U Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Fan Replacement: 2 단계, 이미지 1/2 Gateway NE52214U Fan Replacement: 2 단계, 이미지 2/2
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Fan Replacement, Upper Case: 3 단계, 이미지 1/2 Gateway NE52214U Fan Replacement, Upper Case: 3 단계, 이미지 2/2
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Fan Replacement: 4 단계, 이미지 1/1
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Fan Replacement: 5 단계, 이미지 1/1
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Fan Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Fan Replacement: 7 단계, 이미지 1/2 Gateway NE52214U Fan Replacement: 7 단계, 이미지 2/2
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
  8. Gateway NE52214U Fan Replacement, Fan: 8 단계, 이미지 1/1
    • Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
  9. Gateway NE52214U Fan Replacement: 9 단계, 이미지 1/2 Gateway NE52214U Fan Replacement: 9 단계, 이미지 2/2
    • Gently lift the fan and disconnect the fan from the motherboard.
    • Remove the fan from the device.
결론
Kelsey Rodrigues
회원 가입일: 10/23/18
495 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 UMass Dartmouth, Team S1-G1, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 161
