주요 콘텐츠로 건너뛰기
Gateway NE56R27u Keyboard Replacement
필요한 것
  1. Gateway NE56R27u Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Gateway NE56R27u Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Gateway NE56R27u Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Keyboard Replacement, Hard Drive: 3 단계, 이미지 3개 중 1개 Gateway NE56R27u Keyboard Replacement, Hard Drive: 3 단계, 이미지 3개 중 2개 Gateway NE56R27u Keyboard Replacement, Hard Drive: 3 단계, 이미지 3개 중 3개
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Gateway NE56R27u Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Gateway NE56R27u Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Gateway NE56R27u Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Gateway NE56R27u Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
  7. Gateway NE56R27u Keyboard Replacement, Keyboard: 7 단계, 이미지 2개 중 1개 Gateway NE56R27u Keyboard Replacement, Keyboard: 7 단계, 이미지 2개 중 2개
    • Flip your laptop over to view the keyboard.
    • Using the spudger, push in the ten tabs at the edges of the keyboard.
  8. Gateway NE56R27u Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Gateway NE56R27u Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Using the opening pick, lift the edges of the keyboard.
    • Repeat around the edges of the device.
    • Lift up the keyboard to expose the cables underneath.
  9. Gateway NE56R27u Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Gateway NE56R27u Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Gateway NE56R27u Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
    • Gently pull the mini-DIN cord out of the clamp.
    • Remove the keyboard.
결론
작성자
3다른 기여자 명과 함께
Piper Moeller
회원 가입일: 01/24/20
619 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 738
