주요 콘텐츠로 건너뛰기
Gateway NE56R27u Screen Replacement
필요한 것
  1. Gateway NE56R27u Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Gateway NE56R27u Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Screen Replacement: 2 단계, 이미지 2개 중 1개 Gateway NE56R27u Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Screen Replacement, Screen: 3 단계, 이미지 3개 중 1개 Gateway NE56R27u Screen Replacement, Screen: 3 단계, 이미지 3개 중 2개 Gateway NE56R27u Screen Replacement, Screen: 3 단계, 이미지 3개 중 3개
    • Using the spudger, remove the protective caps for the screen to expose the screws.
    • Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
  4. Gateway NE56R27u Screen Replacement: 4 단계, 이미지 3개 중 1개 Gateway NE56R27u Screen Replacement: 4 단계, 이미지 3개 중 2개 Gateway NE56R27u Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Using the opening pick in between the front cover and bezel, gently loosen and lift the plastic bezel from the screen and backing.
  5. Gateway NE56R27u Screen Replacement: 5 단계, 이미지 2개 중 1개 Gateway NE56R27u Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift the frame of the screen from the top to unhook the frame from the base.
    • When reassembling, hook the bottom of the screen to the base of the laptop before snapping into place.
  6. Gateway NE56R27u Screen Replacement: 6 단계, 이미지 3개 중 1개 Gateway NE56R27u Screen Replacement: 6 단계, 이미지 3개 중 2개 Gateway NE56R27u Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws in the front corners of the metal frame.
    • Lift the screen slightly to expose the connector board.
  7. Gateway NE56R27u Screen Replacement: 7 단계, 이미지 2개 중 1개 Gateway NE56R27u Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Using the spudger, carefully remove the webcam connector from the metal frame.
  8. Gateway NE56R27u Screen Replacement: 8 단계, 이미지 2개 중 1개 Gateway NE56R27u Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Peel the tape covering the display cable, releasing the wire from the metal frame.
    • Unplug the display cable from the image processing board on the screen.
  9. Gateway NE56R27u Screen Replacement: 9 단계, 이미지 2개 중 1개 Gateway NE56R27u Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws from the sides of the metal frame.
    • Remove the screen from the metal frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Piper Moeller
회원 가입일: 01/24/20
619 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 367
