주요 콘텐츠로 건너뛰기
Gateway NV52 Hard Drive Compartment Replacement
필요한 것
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: 1 단계, 이미지 1개 중 1개
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: 2 단계, 이미지 1개 중 1개
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: 3 단계, 이미지 1개 중 1개
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: 4 단계, 이미지 3개 중 1개 Gateway NV52 Hard Drive Compartment Replacement: 4 단계, 이미지 3개 중 2개 Gateway NV52 Hard Drive Compartment Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tim En
회원 가입일: 01/26/13
557 평판
안내서 4개를 작성함
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 회원
CPSU-REGAN-S14S7G24
4 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 4
전체 시간: 1,034
