주요 콘텐츠로 건너뛰기
Gateway NV53A24u Fan Replacement
필요한 것
  1. Gateway NV53A24u Fan Replacement, Fan: 1 단계, 이미지 1/2 Gateway NV53A24u Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
  2. Gateway NV53A24u Fan Replacement: 2 단계, 이미지 1/1
    • Using the spudger, lift the keyboard from its base to expose the underside components.
  3. Gateway NV53A24u Fan Replacement: 3 단계, 이미지 1/2 Gateway NV53A24u Fan Replacement: 3 단계, 이미지 2/2
    • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
    • Then, lift off the shroud to reveal the motherboard beneath.
  4. Gateway NV53A24u Fan Replacement: 4 단계, 이미지 1/2 Gateway NV53A24u Fan Replacement: 4 단계, 이미지 2/2
    • The motherboard is now readily accessible to be removed.
    • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
  5. Gateway NV53A24u Fan Replacement: 5 단계, 이미지 1/2 Gateway NV53A24u Fan Replacement: 5 단계, 이미지 2/2
    • Lift the motherboard up and flip it on its back.
    • With the motherboard flipped, the fan is almost ready to be removed.
  6. Gateway NV53A24u Fan Replacement: 6 단계, 이미지 1/2 Gateway NV53A24u Fan Replacement: 6 단계, 이미지 2/2
    • Locate the fan and its copper heat pipe running just behind it.
    • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
결론
Minh Harper
회원 가입일: 10/11/16
156 평판
안내서 1개 작성함
USF Tampa, Team 1-5, Leahy Fall 2016 USF Tampa, Team 1-5, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 579
