주요 콘텐츠로 건너뛰기
Gateway NV53A24u Fan Replacement
필요한 것
  1. Gateway NV53A24u Fan Replacement, Fan: 1 단계, 이미지 2개 중 1개 Gateway NV53A24u Fan Replacement, Fan: 1 단계, 이미지 2개 중 2개
    • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
  2. Gateway NV53A24u Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Using the spudger, lift the keyboard from its base to expose the underside components.
  3. Gateway NV53A24u Fan Replacement: 3 단계, 이미지 2개 중 1개 Gateway NV53A24u Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
    • Then, lift off the shroud to reveal the motherboard beneath.
  4. Gateway NV53A24u Fan Replacement: 4 단계, 이미지 2개 중 1개 Gateway NV53A24u Fan Replacement: 4 단계, 이미지 2개 중 2개
    • The motherboard is now readily accessible to be removed.
    • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
  5. Gateway NV53A24u Fan Replacement: 5 단계, 이미지 2개 중 1개 Gateway NV53A24u Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the motherboard up and flip it on its back.
    • With the motherboard flipped, the fan is almost ready to be removed.
  6. Gateway NV53A24u Fan Replacement: 6 단계, 이미지 2개 중 1개 Gateway NV53A24u Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the fan and its copper heat pipe running just behind it.
    • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
결론
작성자
3다른 기여자 명과 함께
Minh Harper
회원 가입일: 10/11/16
156 평판
안내서 1개를 작성함
USF Tampa, Team 1-5, Leahy Fall 2016 USF Tampa, Team 1-5, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G5
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 632
