주요 콘텐츠로 건너뛰기
Gateway NV55C49u Display Replacement
필요한 것
  1. Gateway NV55C49u Display Replacement, Display: 1 단계, 이미지 1/1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Display Replacement: 2 단계, 이미지 1/1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u Display Replacement: 3 단계, 이미지 1/2 Gateway NV55C49u Display Replacement: 3 단계, 이미지 2/2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u Display Replacement: 4 단계, 이미지 1/1
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u Display Replacement: 5 단계, 이미지 1/2 Gateway NV55C49u Display Replacement: 5 단계, 이미지 2/2
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  6. Gateway NV55C49u Display Replacement: 6 단계, 이미지 1/1
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u Display Replacement: 7 단계, 이미지 1/1
    • Remove the two 6.0mm #00 Phillips screws from the area under the back cover.
  8. Gateway NV55C49u Display Replacement: 8 단계, 이미지 1/1
    • Remove the nine 6.0mm #00 Phillips screws from the back of the laptop.
  9. Gateway NV55C49u Display Replacement: 9 단계, 이미지 1/3 Gateway NV55C49u Display Replacement: 9 단계, 이미지 2/3 Gateway NV55C49u Display Replacement: 9 단계, 이미지 3/3
    • There are 6 small clips that holding the top row of the keyboard in place.
    • To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
    • Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
  10. Gateway NV55C49u Display Replacement: 10 단계, 이미지 1/1
    • Once the keyboard is loose, slowly lift the keyboard away from the laptop.
    • There will be a single ribbon cable connecting the keyboard to the laptop body. Use two plastic opening tools to loosen the fastener,
    • After the fastener is loose, gently disconnect the cable.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much pressure.
  11. Gateway NV55C49u Display Replacement: 11 단계, 이미지 1/3 Gateway NV55C49u Display Replacement: 11 단계, 이미지 2/3 Gateway NV55C49u Display Replacement: 11 단계, 이미지 3/3
    • Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force.
    • Use a plastic pry tool to disconnect the single pinned connector.
  12. Gateway NV55C49u Display Replacement: 12 단계, 이미지 1/1
    • Use a plastic opening tool to remove the disk drive cover on the right side of the laptop.
  13. Gateway NV55C49u Display Replacement: 13 단계, 이미지 1/2 Gateway NV55C49u Display Replacement: 13 단계, 이미지 2/2
    • Use the metal spudger to pry upwards on the disk drive until you can grab and remove it.
  14. Gateway NV55C49u Display Replacement: 14 단계, 이미지 1/1
    • Now simply lift the face-plate off the laptop body.
    • This step exposes the motherboard, which is a sensitive part of the laptop. Make sure not to touch anything with your bare hands as a static shock could ruin the board.
  15. Gateway NV55C49u Display Replacement: 15 단계, 이미지 1/1
    • Remove the ribbon wire that connects the display to the motherboard using two plastic opening tools.
  16. Gateway NV55C49u Display Replacement: 16 단계, 이미지 1/2 Gateway NV55C49u Display Replacement: 16 단계, 이미지 2/2
    • Remove the two 4.0mm #00 Phillips screws from both the top right and top left of the exposed laptop body.
    • The display is now fully disconnected.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew
회원 가입일: 09/23/18
385 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 342
