이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide if your laptop will not read a USB device or has connection issues during use. This is a difficult process and requires disassembly of the laptop. To replace the USB port you are required to disconnect cables from the motherboard, you will need to make sure not to damage the board.
필요한 것
거의 끝나갑니다!
결론
