주요 콘텐츠로 건너뛰기
Gateway NV55S Screen Replacement
필요한 것
    • At both sides of the bottom of the screen, there are screw covers. Use a flathead screwdriver to remove them.
    • Behind each of them will be a screw. Unscrew each screw.
  1. Gateway NV55S Screen Replacement, Remove LCD Bezel: 2 단계, 이미지 1개 중 1개
    • Use a spudger to remove the bezel.
  2. Gateway NV55S Screen Replacement, Remove lid: 3 단계, 이미지 1개 중 1개
    • At each corner of the LCD will be one screw to remove. Remove each screw, disconnect the webcam (if applicable), and pull back on the lid.
    • Don't forget to disconnect the webcam before pulling the lid back!
  3. Gateway NV55S Screen Replacement, Remove LCD cable: 4 단계, 이미지 1개 중 1개
    • Separate all of the tape from the back of the LCD screen, and then pull straight back on the cable to remove it from the LCD.
  4. Gateway NV55S Screen Replacement, Remove LCD: 5 단계, 이미지 1개 중 1개
    • On each side of the LCD, there are three screws holding it. Remove all of them. You're done!
결론
작성자
3다른 기여자 명과 함께
Joseph Sctbunio
회원 가입일: 09/23/17
7,527 평판
안내서 42개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 98
