주요 콘텐츠로 건너뛰기
Gateway NV59C66u Battery Replacement
  1. Gateway NV59C66u Battery Replacement, Battery: 1 단계, 이미지 1/1
    • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
    • Locate the Latches below the battery.
  2. Gateway NV59C66u Battery Replacement: 2 단계, 이미지 1/1
    • Slide the vertical latch upward, unlocking the battery
  3. Gateway NV59C66u Battery Replacement: 3 단계, 이미지 1/1
    • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
  4. Gateway NV59C66u Battery Replacement: 4 단계, 이미지 1/1
    • Now the battery is free. Proceed to lift and remove the battery.
    • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
    • Take your new battery and position it into the battery slot you took the old one out of.
    • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
    • Put latches in lock position and turn laptop over.
    • Turn on your computer.
결론
Jackson Gandee
회원 가입일: 10/30/19
521 평판
안내서 4개 작성하였습니다
ETECH Holdings ETECH Holdings 회원
Community
2 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 196
