주요 콘텐츠로 건너뛰기
Gateway P-6831FX Heatsink Replacement
필요한 것
  1. Gateway P-6831FX Heatsink Replacement, Heatsink: 1 단계, 이미지 1/2 Gateway P-6831FX Heatsink Replacement, Heatsink: 1 단계, 이미지 2/2
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the Heatsink.
    • Make sure to unplug your laptop charger, as removing the Heatsink while the device is charging may damage the Heatsink and or the charger.
  2. Gateway P-6831FX Heatsink Replacement: 2 단계, 이미지 1/1
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX Heatsink Replacement: 3 단계, 이미지 1/2 Gateway P-6831FX Heatsink Replacement: 3 단계, 이미지 2/2
    • Remove the five Phillips #0 (5mm) screws around the Heatsink.
  4. Gateway P-6831FX Heatsink Replacement: 4 단계, 이미지 1/2 Gateway P-6831FX Heatsink Replacement: 4 단계, 이미지 2/2
    • Gently pull the Heatsink up and away from the chassis.
결론
Chandler Jardin
회원 가입일: 03/19/18
507 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G5, Peak Spring 2018 UMass Dartmouth, Team S3-G5, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G5
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 208
