주요 콘텐츠로 건너뛰기
Gateway SA1 Outer Casing Replacement
필요한 것
  1. Gateway SA1 Outer Casing Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Outer Casing Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Outer Casing Replacement, Disk Drive: 3 단계, 이미지 1개 중 1개
    • Unscrew the marked 5.9 mm Philips screw.
  4. Gateway SA1 Outer Casing Replacement: 4 단계, 이미지 1개 중 1개
    • Use the spudger to pry out the Disk dive.
  5. Gateway SA1 Outer Casing Replacement: 5 단계, 이미지 1개 중 1개
    • The disk drive should easily detach and can now be replaced.
  6. Gateway SA1 Outer Casing Replacement, Outer Casing: 6 단계, 이미지 1개 중 1개
    • Remove the twelve 5.9 mm Philips screws from the back cover.
    • Remove one 8.8 mm Philips screw from the back cover.
  7. Gateway SA1 Outer Casing Replacement: 7 단계, 이미지 3개 중 1개 Gateway SA1 Outer Casing Replacement: 7 단계, 이미지 3개 중 2개 Gateway SA1 Outer Casing Replacement: 7 단계, 이미지 3개 중 3개
    • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
    • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
  8. Gateway SA1 Outer Casing Replacement: 8 단계, 이미지 2개 중 1개 Gateway SA1 Outer Casing Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
  9. Gateway SA1 Outer Casing Replacement: 9 단계, 이미지 3개 중 1개 Gateway SA1 Outer Casing Replacement: 9 단계, 이미지 3개 중 2개 Gateway SA1 Outer Casing Replacement: 9 단계, 이미지 3개 중 3개
    • There will be a connection underneath the speaker cover.
    • Remove the speaker cover using the spudger.
  10. Gateway SA1 Outer Casing Replacement: 10 단계, 이미지 1개 중 1개
    • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
  11. Gateway SA1 Outer Casing Replacement: 11 단계, 이미지 3개 중 1개 Gateway SA1 Outer Casing Replacement: 11 단계, 이미지 3개 중 2개 Gateway SA1 Outer Casing Replacement: 11 단계, 이미지 3개 중 3개
    • Carefully lift the keyboard off from the laptop. It is still attached as shown.
    • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
    • The brown colored component with the tabs does not come out with the connector.
  12. Gateway SA1 Outer Casing Replacement: 12 단계, 이미지 3개 중 1개 Gateway SA1 Outer Casing Replacement: 12 단계, 이미지 3개 중 2개 Gateway SA1 Outer Casing Replacement: 12 단계, 이미지 3개 중 3개
    • Lift up the black tab and gently pull out the connector.
  13. Gateway SA1 Outer Casing Replacement: 13 단계, 이미지 2개 중 1개 Gateway SA1 Outer Casing Replacement: 13 단계, 이미지 2개 중 2개
    • Unscrew the four marked 5.9 mm Philips screws.
  14. Gateway SA1 Outer Casing Replacement: 14 단계, 이미지 2개 중 1개 Gateway SA1 Outer Casing Replacement: 14 단계, 이미지 2개 중 2개
    • Move the wires out of the fixed space as shown.
  15. Gateway SA1 Outer Casing Replacement: 15 단계, 이미지 2개 중 1개 Gateway SA1 Outer Casing Replacement: 15 단계, 이미지 2개 중 2개
    • Unscrew the five marked 3.8 mm Philips screws.
    • Three screws are located on the right side of the screen.
    • Two screws are located on the left side of the screen.
  16. Gateway SA1 Outer Casing Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the screen brackets from the computer's base.
  17. Gateway SA1 Outer Casing Replacement: 17 단계, 이미지 3개 중 1개 Gateway SA1 Outer Casing Replacement: 17 단계, 이미지 3개 중 2개 Gateway SA1 Outer Casing Replacement: 17 단계, 이미지 3개 중 3개
    • Remove the four 5.9 mm Philips screws as indicated:
    • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
    • There are two similarly positioned screws on the right side.
  18. Gateway SA1 Outer Casing Replacement: 18 단계, 이미지 2개 중 1개 Gateway SA1 Outer Casing Replacement: 18 단계, 이미지 2개 중 2개
    • The following steps (18 - 20) explain how to remove the three indicated connections.
    • The order is Blue, Violet, Orange.
    • Lift the white tab up and gently take out the connector.
  19. Gateway SA1 Outer Casing Replacement: 19 단계, 이미지 1개 중 1개
    • Use the spudger to pull off the black attachment.
  20. Gateway SA1 Outer Casing Replacement: 20 단계, 이미지 1개 중 1개
    • Lift and pull the black tab upward until it becomes unattached.
    • Some force may be required.
  21. Gateway SA1 Outer Casing Replacement: 21 단계, 이미지 1개 중 1개
    • Use the spudger to remove the casing as seen in the picture.
  22. Gateway SA1 Outer Casing Replacement: 22 단계, 이미지 1개 중 1개
    • Remove the casing.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Diego Carteno
회원 가입일: 04/15/10
273 평판
안내서 7개를 작성함
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 회원
CPSU-REGAN-S10S24G20
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 16,170
