이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
Remove the hinge covers by lifting each with the sharp point of the spudger.
Remove the six screw covers on the front bezel with the sharp point of the spudger.
Remove the front bezel by prying it off with the wedged end of the spudger.
The screen inverter is now exposed below the LCD.
Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
Unplug the LCD back light cables from the right side of the screen inverter.
Remove the six screws that mount the screen to the hinge mounts.
Two 2.5 mm Phillips screws.
Four 3.8 mm Phillips screws.
Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
