주요 콘텐츠로 건너뛰기
Gateway SA1 Wireless Card Replacement
필요한 것
  1. Gateway SA1 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1개 중 1개
    • The first thing you need to do is remove the panel concealing the wireless card, by taking out the screws.
  2. Gateway SA1 Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the wireless card on the right side of the now removed panel.
  3. Gateway SA1 Wireless Card Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screws in the two possible locations.
  4. Gateway SA1 Wireless Card Replacement: 4 단계, 이미지 1개 중 1개
    • After removing the screws, gently pull upwards on the end of the wireless card until it is angled as shown.
  5. Gateway SA1 Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the card diretly outward from its socket, all while being mindful of the connected wires.
    • Remove the wired connections by gently pulling them diretly away from the card. Please remember where each one was connected, it will be useful for reconnecting
    • Reconnect wires to new wireless card and screw back into place.
결론
작성자
2다른 기여자 명과 함께
Shawn Cabral
회원 가입일: 03/12/14
463 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-4, Cichon Spring 2014 UMass Dartmouth, Team 5-4, Cichon Spring 2014 회원
UMASSD-CICHON-S14S5G4
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 777
