주요 콘텐츠로 건너뛰기
Gateway Solo 1200 Keyboard and Frame Replacement
필요한 것
  1. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: 1 단계, 이미지 3개 중 1개 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: 1 단계, 이미지 3개 중 2개 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: 2 단계, 이미지 2개 중 1개 Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: 2 단계, 이미지 2개 중 2개
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Keyboard and Frame Replacement: 3 단계, 이미지 2개 중 1개 Gateway Solo 1200 Keyboard and Frame Replacement: 3 단계, 이미지 2개 중 2개
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Keyboard and Frame Replacement: 4 단계, 이미지 3개 중 1개 Gateway Solo 1200 Keyboard and Frame Replacement: 4 단계, 이미지 3개 중 2개 Gateway Solo 1200 Keyboard and Frame Replacement: 4 단계, 이미지 3개 중 3개
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Keyboard and Frame Replacement: 5 단계, 이미지 3개 중 1개 Gateway Solo 1200 Keyboard and Frame Replacement: 5 단계, 이미지 3개 중 2개 Gateway Solo 1200 Keyboard and Frame Replacement: 5 단계, 이미지 3개 중 3개
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Keyboard and Frame Replacement: 6 단계, 이미지 3개 중 1개 Gateway Solo 1200 Keyboard and Frame Replacement: 6 단계, 이미지 3개 중 2개 Gateway Solo 1200 Keyboard and Frame Replacement: 6 단계, 이미지 3개 중 3개
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
결론
작성자
5다른 기여자 명과 함께
Riki
회원 가입일: 08/26/19
235 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 7
전체 시간: 377
